clutch????? where to get 1 from???
Old Jan 10, 2011 | 08:34 PM
rosie's Avatar
rosie
Default clutch????? where to get 1 from???
had new master cylinder fitted otherday as was leaking & clutch been fine
gave a abit down bypass last nite & fine threw all the gears
2day i drive 3 miles into town & alls ok, i drive home & clutch slips ob boost???
gotta be clutch aint it????
clutch slips then bites
car is only std so dont require anythin other then a std replacment
wheres best to buy from?? how much?
cheers
Old Jan 11, 2011 | 10:14 AM
I would still shop around, look at ford's price, ebay, and also look at uprated ones, if you can get one of these for not much more it would safeguard against any future mods you might want to do, don't know power wise what the std one will take.
Old Jan 12, 2011 | 01:00 PM
CarParts Express's Avatar
CarParts Express
what engine/model?
Old Jan 12, 2011 | 01:12 PM
Sp3no's Avatar
Sp3no
Could also be the slave cylinder leaking onto the clutch friction plate but if you fit a new clutch you should fit a new one of these anyway and vice versa, if you are planning on swapping the slave clylinder you may as well do the clutch while your there.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
