urgent help required!!!!!!!!
i have problems starting my 89 saff cos, i have checked the ignition switch, replaced the starter motor, and run a direct feed off the battery to check the starter,the starter is fine, i dont even get power drain on the final click of the ignition key.
can someone please please please, tell me the exact location of the starter relay and how to identify it please, and also any relevant fuses in the system .
thanks
cossiedaz
thanks
cossiedaz
there was a break in the cable between the starter and ignition key, dunno where tho , i just changed the whole cable and now its fine
thanks for the advice anyway hectori
wowk
Mar 30, 2021 07:49 PM
