Do P8 cossys have knock control?
Old Jan 31, 2005 | 05:59 PM
cosworthbg's Avatar
cosworthbg
Default Do P8 cossys have knock control?
As title
Old Jan 31, 2005 | 06:37 PM
Stu @ M Developments's Avatar
PassionFords Creator
Yes, as std it does
Although Pectel hardware may have disabled it, i dont recall if P8 Pectel retains it or not, im thinking not.
Old Jan 31, 2005 | 06:39 PM
ECU Monitor Enthusiast
It doesnt as far as I know.
Knock control on P8 is useless above 4000 rpm anyway !!!
Old Jan 31, 2005 | 06:49 PM
cosworthbg's Avatar
cosworthbg
Thanks for answers m8s,but wehy is it useless??
I'm trying to sort out if Ishould use some kind of ignition retard module when I use nitrous,in order to lower detonations that may accur.. or I can trust on the original knock control
Old Jan 31, 2005 | 06:56 PM
Control of knock on production engines can be confused with internal
high speed mechanical noise of the moving parts as the engine wears.
In effect, if it ran closed loop continuously, as the engine wears over time
(even after a few 100 miles) the high frequency component of the
noise confuses most knock systems that knock is active when it isnt.
The result is ignition retard and power loss.
Nearly ALL ecu's that employ knock control disable the feature after a certain rpm
and over a pre-determined boost pressure level.
Another reason for this is....
If the knock sensor failed during high load situations, the closed loop action
could in effect have the reverse effect of advancing the ignition as it may
think there is NO knock and this COULD result in producing DET.
Old Jan 31, 2005 | 07:19 PM
cosworthbg, DO NOT rely on a knock sensor to control ignition for nitrous.
Even when working it will NOT react quick enough to prevent damage
under heavy load.
On a cossie (weber ecu) system, the ignition can be retarded very easy under nitrous
as there is an octane adjustment plug that can retard the ignition by 2,4,6 or 8
degrees by linking two or more wires together. (when NOS is active)
However, This is VERY chip manufacturer/ECU type dependent and will have to be
live tested under load by someone who knows what they are doing to
prevent "liquid pistons".
Old Jan 31, 2005 | 07:26 PM
cosworthbg's Avatar
cosworthbg
cosworthbg,
10x SECS ,but where exactly is that octane adjustment plug situated???
Old Jan 31, 2005 | 07:27 PM
GARETH T's Avatar
GARETH T
under heavy load.
thats something ive never thought about doing great idea
tankybaby66
Feb 6, 2016 02:24 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
stevecfrst1
Sep 30, 2015 05:18 AM
