Cosworth 2wd no spark or injectors or anything
Old Jan 8, 2011 | 03:50 PM
potterrs's Avatar
potterrs
Default Cosworth 2wd no spark or injectors or anything
Hi all, i'm having problems with my 2wd sapphire.
I have tried the following
Crank sensor tested and reads 596 ohms, i know it should be between 600 and 1200 but would 4 ohms make a difference?
Phase sensor new from msd and resistance correct at the ecu plug
the fuel pump relay doesn't earth out at the ecu to make the pump run
coil sparks once when the ignition is turned on
all the old immobilisers have been removed
there is live to the injectors but no pulseing earth when cranking
crank sensor air gap is .7mm
There is + and - to the ecu
I'm thinking the ecu is faulty or maybe the crank sensor
Sorry for the essay but this one has got me baffled, any help would be greatly appreciated,
chris
Old Jan 8, 2011 | 03:58 PM
martysmartie's Avatar
martysmartie
The fuel pump should prime when the ignition is switched on but it won't do so unless it receives an input for the CPS, you would also not have a spark, check the connector for the CPS as this is a vulnerable part, the pins sometimes loose there grip inside and so a no connection situation.
Martin
Old Jan 8, 2011 | 04:12 PM
potterrs's Avatar
potterrs
Ok thanks i'll try a new one and see what happens, what you say explains all my problems. Thanks
Old Jan 8, 2011 | 04:17 PM
potterrs's Avatar
potterrs
i have tested the resistance just now at the ecu multiplug with the same results
Old Jan 8, 2011 | 04:43 PM
Matt Lewis's Avatar
Matt Lewis
RS & ST Parts Specialists
Had a problem like this and it turned out to be a dodgy rotor arm!!
Old Jan 8, 2011 | 08:07 PM
The sensors appear ok(4 ohm won't make a difference), the ecu is NOT outputting to the relay, which powers the fuel pump, it won't run without fuel, the pump will NOT prime all the time, stick a earth on the relay and see what happens, then follow wire back to ecu, if truly not outputting a earth to trip the relay, the ecu is duff, but easy to get around, hopefully will just be a dicky connection on the earth output.
Old Jan 8, 2011 | 09:17 PM
Stu @ M Developments's Avatar
PassionFords Creator
What happened between it running fine, and not doing?
Old Jan 9, 2011 | 03:44 PM
potterrs's Avatar
potterrs
Tried another ecu today and it fired up straight away
Old Jan 9, 2011 | 03:46 PM
potterrs's Avatar
potterrs
Thanks for the help everyone
Old Jan 9, 2011 | 05:58 PM
martysmartie
No problem, glad it's sorted.
Martin
SmudgerByName
52
Jul 28, 2016 06:14 PM
wheelwizardrefurbs
Aug 29, 2015 09:25 AM
Aug 14, 2015 07:29 AM
Zoggon
Aug 10, 2015 10:39 AM
Old ford
Jul 31, 2015 06:50 AM
