engine timing procedure ?
Old Jan 7, 2011 | 10:27 PM
liamford's Avatar
liamford
Default engine timing procedure ?
hi guys
im taking the head of my small turbo cossie to change the valve stem seals, but im not to sure on the setting of the timing set up? when the head goes back on.
Any help would be much appriciated.
thanks liam
Old Jan 9, 2011 | 06:53 PM
cozzy jeff's Avatar
cozzy jeff
time it up like this before you remove you head,then make sure they go back the same way.
Old Feb 2, 2011 | 01:24 AM
gog's Avatar
gog
Hi Liam, have a Cosworth Manual if you want to borrow it? also a crank pulley puller!
Let me know,
Regards
Gog
Old Mar 3, 2011 | 10:16 PM
liamford's Avatar
liamford
hi gog, i have decided to get my mate to do the job, to busy with work at the min...thanks for the offer tho mate !
RUBY123
Oct 22, 2023 12:04 PM
Bailes1992
Aug 16, 2015 07:14 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
taylora1409
Aug 12, 2015 12:06 PM
Old ford
Jul 31, 2015 06:50 AM
