Air to Air injectors
Old Jan 31, 2005 | 04:58 PM
cosworthbg's Avatar
cosworthbg
Default Air to Air injectors
Hi,can someone explain what's the benefit of using air to air injectors instead of amal valve?? How exactly do they work?
Martin
Old Jan 31, 2005 | 05:36 PM
cosworthbg's Avatar
cosworthbg
Old Jan 31, 2005 | 05:41 PM
S1 Barkham's Avatar
S1 Barkham
Think it's more accurate boost controller
Old Jan 31, 2005 | 06:27 PM
cosworthbg's Avatar
cosworthbg
Old Jan 31, 2005 | 06:30 PM
Stu @ M Developments's Avatar
PassionFords Creator
Hmm..
Its actually quite a complex subject this one. If no one has kindly dealt with it, il tackle it for you later with a beer
Old Jan 31, 2005 | 07:23 PM
Daviet's Avatar
Daviet
another good read coming up
Old Feb 1, 2005 | 10:46 AM
Damn, No one helped you barstewards
Ive an engine to get on with stripping so il make this more brief than i maybe would have done last night had i not fell asleep
There are various ways of introducing a controlled boost pressure increase above the base actuator level (IE actuator preload level) and the main 2 are:
Bleed Off & Bleed on.
Bleed Off:
This is what an Amal valve does. It bleeds a set amount from the original boost signal via the "R" port in a 3port system or via the outlet port on a 2 port system. Either way, it controls an air leak on the actuator - compressor pipe, thus raising the boost level. This can be mapped in fashion by altering numbers in the boost map so that the valve is pulsated at a set frequency which we can vary slightly with RPM. What we cannot do, is set any real boost curve using this primitive method.
Bleed On:
This is what Air Injectors do.
This sytem usually uses a totally closed system so the compressor signal pressure is at the intake end of an injector or 2 and the wastegate pipe is at the nozzle end. This way, the amount we pulse the injectors will vary the amount of air that reaches the wastegate. Due to the way this system works we can ensure that no pressure at all reaches teh gate until we want it to, thus ensuring as rapid a spool up as the turbo can give us, presuming no excess turbine housing pressure causes wastegate creep. One of teh main benefits is teh fact once we have started to rev the engine and our boost begins to tail off naturally, we can virtually close the wastegate if required and force the turbo to give us every last ounce of boost it can, should of course we wish to do this. The system is far more mappable due to the finite adjustment an injector nozzle has in relation to a simple solenoid that is the Amal valve.
Important:
Remember that Bleed on and Bleed off are technically electrical inversions of each other so the system needs to have the boost map control inverted to use one or teh other. IE: Fully open max boost in an amal valve map would give no boost on an AI map. To alter this you have to either:
1) Use an AI Inverter such as we manufacture & use. (L1, L6 or L8)
2) Run Pectel hardware/software which will enable this if required. (L8 or P8 only)
I hope this has helped.
Old Feb 1, 2005 | 10:53 AM
R4N SS's Avatar
R4N SS
Stu -
Old Feb 1, 2005 | 11:27 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Stu,
Pectel can convert L6 to run air injectors as well Stu . It costs Ł125 to upgrade to a Pectel CPV2 board and modify the ECU for boost control.
Old Feb 1, 2005 | 11:37 AM
I didnt realise people were still doing the level 600 conversion Mike, thanks for that info
Old Feb 1, 2005 | 05:14 PM
for cosworthbg
Old Feb 1, 2005 | 05:36 PM
cosworthbg's Avatar
cosworthbg
Cheers STU,you've been very helpfull
Old Feb 1, 2005 | 07:56 PM
tracktoy's Avatar
tracktoy
Old Feb 1, 2005 | 08:02 PM
Gaaables's Avatar
Gaaables
always wondered that, nice1 stu
now get back to that engine
mk3ste
Oct 17, 2021 10:09 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
