My garage
i built a big one like that last year it was 55ft long 25ft wide roller doors on either side you could drive rite thru it.wish i had pic's off it. yous would off loved to see the cars that went in to it. all old cars one off them was worth Ł175000 there was a few off them in when i was puting the skirting on i was shiting myself incase i hit one.
It PVC sofit board.
Normally used like this,
But i just ussed it as full length along the walls.
It Tunged and Grooved so it easy, cant remember right, but you have to start at the bottom and work up.
Its cheap. but only good if your use ply on the inside of garage for strength.
i used it on the 2 wall faceing the front of the house, the back to walls are Galvanized sheeting.
Heres a pic half way trought.
yup bottem up. hehe
didnt realise when looking at the structure that your spread between the roof rafters was so big...great project and an easy build by the looks of it...i think i mentioned it to you on the IEC site about the lack of use of dpc under the timber frame, personally i think that was not a good move....how did it cope with the big snow fall we had??? im gonna go ahead and build the shed now after seeing this again....i never thought of using the soffit board as a finish....the garage looks the job man...
I built one very very similar a couple of years back, prob my best mod ever.. Stands me in about 2k in total including all the electrics. I'll post up some pics...
Its 18ft X 15ft. Comfortably fits in two cars that can be worked on at the same time
like to see pics as my one im doing now is 15ft wide and 20ft long
Roosie.... I'll get some up tonight if not over the weekend.. I kinda got a bit carried away with the base and it ended up about a 10 inches roughly, which actually did me a favour as now have a gentle curver near the doors which stops the rain etc getting in..
Iv 5 inches of concrete in mine, with 2 of them 3x5meter steal grid mesh jobys.
More then enough, my drive is only 4 inch with no steal, and the 20 tonne lorry delivered the concrete by driving over that, and that was fine,
heres my damp proof membrane below concrete...........the blue stuff
the weld mesh reinforcement that i put in.................
finally a couple of pics of mine in progress........a total mess..........but will get it sorted out soon
inside lol.........................
people keep telling me to put hardcore down but does it really need it?
im going 5"deep with metal gridding and damp proof membrane.
its only going to have cars in there nothing heavy
also im going 16ft wide but can go 18ft if i want to but its going about 30ft back
your only goin to do it once so better to do it right mate
the rule of thumb roosie is to dig out any soil that is capable of growing vegetation ,and as a builder i would 150% put hardcore underneath it to support the concrete .make sure you roll or whack in the harcore as well.
i would dig down minimum 14 inches and put 8 inches of hardcore and then blind it off with 1 inch of sand ,lay a 1200g visqueen/plastic membrane on top and put a layer of 383 mesh in then lay 5/6 inches of concrete on top of that.
one of the problems with concrete cracking is when the soil heaves /expands in wet conditions.thats why you should take the soil down to the harder subsoil underneath.
all the measurements are what i would use as a minimum to be safe
