ST170 heavy steering when cold
Old Jan 3, 2011 | 10:33 AM
mcst's Avatar
mcst
Default ST170 heavy steering when cold
As title really, for the first mile or so there's heavy resistance at the top when turning right but once its had a bit of use its fine. Its the mrs' car and i've been driving it lately - apparently its been doing it a while
Is the pump on its way out or is it just the fluid breaking down?
Any help appreciated
Old Jan 3, 2011 | 03:25 PM
I'd try some wynns power steering system stop leak, this is also a reconditioner of the seals, and from personal use can tell you it works very well, esp in sluggish auto boxes that lose drive.
Old Jan 3, 2011 | 03:42 PM
steves24V's's Avatar
steves24V's
I've changed a rack on a st170 had a simlar prob to yours it was tight to turn one just past center one way, was all good after it was changed also done a lot of mondeos.
Old Jan 3, 2011 | 07:50 PM
mcst's Avatar
mcst
Thanks for the recommendation. Theres no obvious signs of a leak but the fluid is just above the minimum when cold
Were they doing it all the time though? This stops once its been worked for a mile or 2 and is fine until next morning or if its left for quite a few hours.
Old Jan 3, 2011 | 08:42 PM
Its not the valve in the pas pump getting stuck is it.I had a similar fault on a tranny van at work the other day.Its was as if there was no pas at all,then all of a sudden it started working.
Old Jan 3, 2011 | 08:49 PM
martin24uk's Avatar
martin24uk
i had the same problem in my diesel van, just changed the power steering fluid
as over the years had become contaminated and just crap looking.
has been fine ever since....
Old Jan 3, 2011 | 08:58 PM
steves24V's
I cant remember now, this sort of had a heavy/ stiff patch just right from center, so made it hard to mark small corrections on a straight road if you know what i mean.
If yours is heavy all the way from lock to lock it mite not be the same thing, also its easy to pop off the uj's where they go onto the rack inside the footwell i did this just to check them first. not that they normal gave trouble like sierras because they are inside the car.
Old Jan 4, 2011 | 07:23 AM
mcst's Avatar
mcst
Mine does that, its just the first 30deg or so but it disappears once warm.
Will replace the fluid as a starting point as its on minimum and looks pretty shitty.
Old Jan 6, 2011 | 05:14 PM
fdove3's Avatar
fdove3
The ST's sprint to 60mph takes just over six seconds and a top speed in the region of 150mph will be more than adequate. Wet traction off the line isn't the greatest but lateral grip is superb. The Volvo-sourced powerplant serves up a big slug of torque between 1,700 and 6,750rpm. It's this driveability that makes the Focus ST such a formidable weapon.
Breitling Avenger Chronograph replica
San Antonio podiatrist
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
tankybaby66
Feb 6, 2016 02:24 PM
A.t.p
Oct 23, 2015 07:54 PM
