My Escos Shell *SOLD*
Almost there!
Right, here goes
the way ive valued everything on the car is based upon how others have sold similar items over the last year/or average prices for the items, but maybe come down slightly in price on many of the bigger items.
obviously id like to sell this as a complete unit, the prices below are a breakdown of how ive come to a final figure!!
all i will say, is that the number plate will not be included in the sale.
Shell, to include doors/glass/cage/WRC front wings and wiring loom etc
also has perspex rear windows, carbon door handles and wing mirror bases, removable front bar for bigger intercoolers.
it does have I.D and will have a registration assigned once my plate is removed!
cage is in T45 and fully TIG welded, picks up the rear diff mounts and works thru the front bulkhead to the turrets.
also has a welded in but main section removable front strut brace between the struts - £4500
Grille - £50
Front Bumper - £300
Rear Bumper - £300
Side Skirts - £200
Flocked Dash/Door cards - £150
Rear spoiler & Carbon Wolf - £350
Morette Headlights - £200
RS500 Foglights - £75
Quick Release OMP Steering Wheel - £200
3dr front hubs/steering rack/ ARB/TCA's/Crossmember - £250
Avo 2wd Coilovers - £275
Adjustable Rose Jointed top mounts - £325
2wd Rear beam/arms - £75
ABS ECU/Brake Resevoir/Brake control unit etc - £100
2wd Gearbox (suspect 3rd gear issue) - £150
Total for above comes to £7,500, but id say £7,000ono
extras from then would be negotiable or sold individually.....
OMP Pista Carbon Kevlar bucket seats (normally retail @ £1350 each and have actually come out of Matt Neal & Dan Eavs touring cars, then the centres retrimmed in Alcantara with 'Reyland' stitched into them) - £800
OMP black harnesses to match, 4 point with aditional crutch strap - £150
Stack Dash, with the 4 bar bost gauge - £1000
Centre dash gauge panel housing 4 stack gauges - £400
a few Random pictures in no particular order of its build up and goodies
Grille - £50
Front Bumper - £300
Rear Bumper - £300
Side Skirts - £200
Almost there!
As for the deal.... Hmmmm
Andy speaks sense
Not quite Steve, the focus has it's money allocated already
Almost there!
Upski.
4.5k gets you the shell with the items mentioned next to it, if you then want anything else then we can add them on as we price things up.
alot of potential in the right hands, or a tatty MOT failure saph as adonor vehicle and it would be pretty much there
very bad time year to sale, people will say its a year older an need to lower the price, people need to take into account how much it costs to get the cage built/fitted/top mounts all those little bits all add up, to buy a bare shell then get that work done same as yours i bet you wouldnt have much change from 7-8k then add the other bits etc, this is very cheap car in my eyes an i hope a buyer see this to a takes it, was one of my fav escorts with rl7s
Almost there!
Exactly that Andy
the cage alone was best pasrt of 3k, then add the front wings into the equation.
you also need to have an escort shell to start with aswell.
plus add the perspex, carbon bits, dash and doorcards which are flocked, removable front panel and front top mounts.
£4500 is a cheap shell
Just see this KELV sad times... Good news to any potential buyes though...The cage is a full T45 tig welded cage and not CDS as in the add above, T45 is our top grade rollcage material! Those that dont know I built the cage hence why I am correcting details
Good luck with the sale.
Almost there!
cheers Danny, i always got muddled up with which material was which, i knew it was the better, lighter material that i opted for, thanks for correcting that
Cage work is awesome
got your PM aswell, ill dig up what i can for you and give you a shout
Almost there!
The shell is now allocated to a sale, but wont be officially sold/collected for a short while.
all of the rest of the goodies will be put up for sale over the weekend
Almost there!
i was speaking to Lee the other day and we spoke of yourself Pete, i thought he had told you about it already as he said it would be ideal for you.
ive still got your number anyway, unless its changed over the past year or so.
if it goes pair shaped ill give you a heads up
