xr3i hot start probs
Old Dec 31, 2010 | 08:26 PM
andymex4481's Avatar
andymex4481
Unhappy xr3i hot start probs
help if you can
ive got a 1988 escort xr3i with k jetronic
it starts from cold great, runs and drives great but if turned off after a while wont start
between 15 mins and two hours after that first turn of the key starts up again
i fitted a new pump relay but no better
when it wont start it has a good spark and fuel pressure up to the dist unit hope you have some ideas cheers andy
Old Jan 1, 2011 | 04:14 PM
martysmartie's Avatar
martysmartie
On these they have a cold start plug (It's blue) I know these cause problems I think if you disconnect it and it starts better then it means thats the problem and needs replacing, can't remember though if it's for cold or hot start problems.
Martin
Old Jan 1, 2011 | 06:51 PM
andymex4481
not sure what part you mean it has a cold start injector
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
StephTell
Sep 2, 2015 06:31 PM
kevin36
Sep 2, 2015 06:24 PM
