Cosworth L8 ecu etc what does Pin 10 do?
Old Dec 29, 2010 | 10:18 AM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Default Cosworth L8 ecu etc what does Pin 10 do?
I know for sure that pin 10 on all the Cossy Weber ecu's gives an earth to the EFI relay, is this simply an earth that's there all the time provided the ecu is plugged in?
Old Dec 29, 2010 | 10:24 AM
stevieturbo's Avatar
stevieturbo
C**t
Some cars use it like an immobiliser feature. Where the key tells the ecu to to turn on....then part of the ecu actually activates a power relay to turn itself on. If that makes sense.
I think it's the same pin I had to earth out when I fitted an aftermarket ecu with a patch harness in order to make it power up via the key as the OE ecu was no longer plugged in.
Old Dec 29, 2010 | 10:40 AM
vaughant's Avatar
vaughant
Switched earth?clever.so if the thief tries to put power directly to it it should blow something internally to prevent the car being started.could also provide a safety feature for voltage spikes etc.
Old Dec 29, 2010 | 10:44 AM
stevieturbo
C**t
not really claver, earthing it will energise the relay.
But a lot of ecu's become a remote trigger to power the ecu and other circuits up now. I guess easier to link the immobiliser functions inside the ecu to start with.
Hence why many components on modern cars need coded to the ecu etc.
Old Dec 29, 2010 | 10:48 AM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
This any good Mart
Old Dec 29, 2010 | 10:49 AM
Richie.'s Avatar
Richie.
aka Turbosailorboy
Old Dec 29, 2010 | 10:50 AM
Martin-Hadland
Thanks Richie but I already have a diagram I just wondered if there were and circumstances where the ecu could remove the earth.
Old Dec 29, 2010 | 10:52 AM
NEIL A's Avatar
NEIL A
Alot of info on ECU's on this site
http://www.bigturbo.co.uk/
Old Dec 29, 2010 | 10:53 AM
Richie.'s Avatar
Richie.
aka Turbosailorboy
How does it prevent the fuel pump priming if there is no crank signal ? ? ?
Old Dec 29, 2010 | 11:02 AM
Martin-Hadland
Because the EFI relay controls the pump, no earth to the EFI relay means no pump working too.
Old Dec 29, 2010 | 11:05 AM
Richie.'s Avatar
Richie.
aka Turbosailorboy
Because the EFI relay controls the pump, no earth the EFI relay means no pump working too.
Old Dec 29, 2010 | 11:06 AM
Martin-Hadland
Do you have a higher res version of that diagram Richie?
Old Dec 29, 2010 | 11:07 AM
Richie.'s Avatar
Richie.
aka Turbosailorboy
I have them in PDF.............Whats your email ? ?
Old Dec 29, 2010 | 11:11 AM
Martin-Hadland
martin@reyland.co.uk
Old Dec 29, 2010 | 11:34 AM
ECU Monitor Enthusiast
Martin,
Pin 10 is simply a safety backup interlock for the fuel injection system.
As said above, it provides an earth for the main power relay that supplys the whole system.
Remove the ecu and all the components relating to engine drive are de-energised except the ignition module and coil.
The ecu cannot switch this signal.
Some ecu's provide this earth via a diode but that doesnt affect how it works.
Old Dec 29, 2010 | 11:35 AM
Martin-Hadland
Thanks Richie
big_Rad
Sep 15, 2017 09:36 AM
manuel boeckx
13
Oct 3, 2015 02:29 PM
James Porter
Aug 14, 2015 12:43 PM
Aug 14, 2015 07:29 AM
M K
Aug 12, 2015 06:57 PM
