ECU Repair
Is there any where i can send our Fiesta RS1800 ECU away for repair?
We had the car looked at as it wasnt run right and it turns out its the ECU so i need to either get the one we have here fixed or try and find another ECU
Anyone able to help
Cheer's Brian
Anyone able to help
Cheer's Brian
Try these people, they may be able to help. We have used them many times and are reliable.
http://www.bba-reman.com/catalogue/P...px?category=86
Brian
If someone has been inside the ecu then it is probably dead..now !
Its unusual for them just to fail as they more liekly get confused with the wrong information when there are loom or sensor faults.
If you send it away for repair make sure you get a quote first.
I suspect. you will repair or replace it only to find the fault still exists or reappears.
Good luck
Good luck
Good luck
Good luck
Brian
oh the other option is you could disable the pats (i assume you have a proper alarm an immobaliser) its a case of changing a few wires round at the ecu plug and you can use a pre pats ecu which are much much more common
ahh shite forgot about EDIS
to do the above you'd have to wire in an EDIS module as well which is a bit more work, but realistically you could sort it with a Ł15 ecu and an edis module and a bit of wiring
JDmsport (CRSpares@aol.com) almost always has xr3i 130 parts in stock drop him an email
Bri,
my mate knows a electronics genius who works for the raf fixing the plane ecu's and stuff,he does a nice sideling in car ecus and they tell me theres so many ecu's that come in with damp in them,they dry loads out and they work fine again when tested so its worth checking its bone dry first which will cost you zero.
also i know camco 88 who can fix ecu's and unlock them,they used to tune escort and fiestas once although now concentrate on just ecus.
HTH
HTH
Bri,
HTH
HTH
nice one fella.
they do other stuff too i shoulda said, heres the website
http://www.camcoautomotive.com/
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
rsguy
44
Sep 29, 2015 03:29 PM
