Air charge temperature gauges
Old Dec 20, 2010 | 12:53 PM
coleman's Avatar
coleman
Always in the background
Default Air charge temperature gauges
I'm looking for one of these and was wondering if anyone has used the following?
http://cgi.ebay.co.uk/Air-Charge-Tem...item19c1d79145
If not, what do you use?
Edit
Just to say its not for a ford cosworth but a impreza, but im sure i could make the one above fit!
Old Dec 20, 2010 | 01:16 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Does not say if it comes with a sensor or not, if it doesn't and it's designed to work with a Cossie ACT sensor then it will most likely not work with an Impreza one.
Old Dec 20, 2010 | 01:21 PM
RigPig's Avatar
RigPig
Speak to Mike Rainbird mate, he should be able to help you.
Mark RS
Oct 12, 2015 06:01 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
