Escort RS Turbo Series 2 - Various Parts
Old Dec 12, 2010 | 04:10 PM
Rogeyboy's Avatar
Rogeyboy
Default Escort RS Turbo Series 2 - Various Parts
I'm having a clear out of my garage, so i've got alot of stuff to shift and will give you all 1st refusal. Whatever doesnt sell on here will be going on Ebay!
90 Spec ERST Rear Bench & Backrest, good condition bit grubby - £20
Koni Adjustable Front Shocks with 35/40mm lowering springs, around 2 years old, working fully with some surface rust on shock bodies - £100 posted
Standard 260mm ERST Front brake calipers, discs & pads, discs & pads have plenty of meat on them standard compound i beleive - £65 posted
Both ECU's fully working from an 89'Plate ERST - £95 the pair or £50 each posted
Standard Inlet manifold & throttle bodie - £50 posted
Magnex Stainless exhaust system, 2.5in system, 4in Inwardly rolled tailpipe with flexi section - £100
Magnex Flexi section + downpipe - £40 posted
Scorpion stainless exhaust system, 2.5in system + 3in Inwardly rolled tailpipe £100
Windscreen, non heated, no visible damage - £30
Complete ERST Engine, head + block. Unknown spec, presume standard. Covered 87k, no smoke or knocks or bangs etc when removed. Been dry stored in my garage 6months - £300
LSD Gearbox, no whines or noises. Removed with engine from car around 6months ago at 87k - £120
Standard T3 Turbo, rebuild advised due to play in shaft £offers
Standard Radiator + Intercooler, no leaks on either but some damaged fins - both £100 posted or £65/£35 posted respectively.
Standard actuator, used to hold 8psi on above engine & turbo. Holds pressure + vacumn when tested £10 posted
-31 Actuator used but not by myself. Holds pressure + vacumn when tested £15 posted
Various other bits and bobs hoses + sensors etc, PM me if you need anything!
Everything that can't be posted. Ie Engine, gearbox, windscreen, exhaust and rear seats. Can be collected from Essex.
Open to offers on Anything - PM Me Please!
Old Dec 12, 2010 | 04:37 PM
stevealien's Avatar
stevealien
10 Year Member
Hi mate. What spring on the konis ?
Any pics ?
Old Dec 12, 2010 | 07:00 PM
EssexMikeSi's Avatar
EssexMikeSi
dont suppose u have the master cylinder and reservoir bottle do u?
Old Dec 12, 2010 | 08:08 PM
martinmilne's Avatar
martinmilne
wher are you mate
Old Dec 12, 2010 | 08:25 PM
mr noisy's Avatar
mr noisy
Hello matey how much play does the T3 have ? i have one on my car at the mo dont smoke but lots of play
May also have the -31 too
You got any blue samco pipes ?
Old Dec 12, 2010 | 09:02 PM
Rogeyboy's Avatar
Rogeyboy
Got some blue samco's yeh, throttle body to crossover and 1 other...
T3 doesnt have much play, but then its all opinion - im just saying it needs a rebuild to cover myself!
Im in Essex
No brake res/master cyl im afraid!
Old Dec 12, 2010 | 09:14 PM
mr noisy's Avatar
mr noisy
Did it smoke matey ? whats the best you can do matey ??
Old Dec 13, 2010 | 09:34 AM
XR2000STEVE's Avatar
XR2000STEVE
im interested in the gearbox mate im close to you and can collect i will be out of the country until the 28th any chance you can hold it for me ? also looking for a turbo bonnet and front bumper send me a text on 07799731482 if your interested
Old Dec 13, 2010 | 04:20 PM
faststu's Avatar
faststu
once again
hi payment sent for -31 thanks from stuart
Old Dec 13, 2010 | 04:33 PM
ryan_gwa's Avatar
ryan_gwa
You would happen to have an ERST engine loom in your wee collection??
Ryan
Old Dec 13, 2010 | 06:41 PM
robrs666's Avatar
robrs666
Hi mate I'm after a heater matrix don't suppose you have one do you thanks mate
Old Dec 13, 2010 | 07:02 PM
Lawbags's Avatar
Lawbags
You got a drivers seat belt by any chance?
Old Dec 13, 2010 | 08:21 PM
Rogeyboy's Avatar
Rogeyboy
Loom, sold sorry!
Heater matrix, i'll check
No seatbelt im afraid!
Old Dec 16, 2010 | 06:20 PM
faststu's Avatar
faststu
once again
got the -31 today thanks very much
Old Dec 16, 2010 | 08:46 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
intrested in the rear bench mate , but you wont courier it
Old Dec 17, 2010 | 11:38 AM
Rogeyboy's Avatar
Rogeyboy
Stu - No worries, glad to be of assistance!
Beefy - Where r u located?
I could courier it, or you can arrange courier to collect - Pm me.
Old Dec 31, 2010 | 09:27 AM
Rogeyboy's Avatar
Rogeyboy
-31 Sold
Gearbox Sold...
Anyone want any bits, make me an offer!
I need to clear some space!
Old Dec 31, 2010 | 05:38 PM
dirtysteve's Avatar
dirtysteve
hi mate, do you still have the radiator?, if so where in essex are you?, cheers, Steve
Old Jan 1, 2011 | 10:55 PM
DanFR147's Avatar
DanFR147
Hi Mate, do you still have standard actuator? If so I'll have it off you. Txt me on 07796008817, cheers, dan
Old Jan 4, 2011 | 11:58 AM
Rogeyboy's Avatar
Rogeyboy
PM'd...
Beefy - You want seats, if not they r going on Ebay!
Old Jan 4, 2011 | 05:19 PM
morph's Avatar
morph
Have you got standard set of alloys?
Old Jan 4, 2011 | 05:32 PM
chris m1's Avatar
chris m1
postcode to check distance..Intrested in the rear seats
Old Jan 6, 2011 | 07:57 PM
Rogeyboy's Avatar
Rogeyboy
No Alloys im afraid...
PM's for postcode!
Old Jan 6, 2011 | 08:01 PM
Rogeyboy's Avatar
Rogeyboy
Radiator - Turbo - Koni's and Both Actuator's
NOW SOLD!
Vincereese
Jun 1, 2023 09:14 AM
3i Jim
Nov 20, 2015 05:12 AM
Vincereese
Aug 16, 2015 06:38 PM
muz
Aug 16, 2015 12:57 PM
adriansaleem
Aug 1, 2015 09:28 PM
