Series 2 cage
Been fitting a Safety Devices 6 pointer to my RST over the last couple of weeks....thought I'd show you
Its unbelievably tight in the car.... it pressess up hard against the A post, roof and dash (I can't use the glove box anymore
Now its time for these
Originally Posted by Tim
lol wish our lass was like that
Cage was about £350 I think,
I was amazed how tight they manage to build them
Another few mm here and there and I don't think it would have gone in Trending Topics
looks good mate, did you seam weld the plates to the floor ??
also when I spoke to SD they told me these;
go under the arches, to make it like a sandwich and prevent the bolts pulling through the ford arch as you tighten them
Damo V - The plates were fully welded in (the pictures just show them tacked before we finished them off.
To be honest I wasn't sure if thoses plates went on top or under but they fitted nicely on top so thats where I put them.
Will probably put some big washers on the underside
No, the plates are in the right place for the MSA logbook rules, it's good to see them finally put in the right place for once! Looks lovely.
Andy
Andy
Andy
Andy
nice one john, excuse my ignorance, but i aint been around for a while, didnt it used to be black?!
i think i would like some carpet back in mine, just gotta stop the fookin sunroof leaking first
someone pass me that hammer
cheers, chad.
someone pass me that hammer cheers, chad.
cheers, chad.
Nah I took the black one to bits to clean it all up and never put it back together
I sold it on and got this minter instead Swopped all the bits across and bobs you uncle
You just buy the washers, the theory is that the cage is in so tight it won't pull out as it's resting against the opposites, if you put the plates underneath and don't weld it then it just pushes the cage through the floor in a crash.
Kiran1600E
11
Oct 2, 2015 11:35 AM
muz
Sep 30, 2015 08:29 AM
SMILER258
Sep 28, 2015 09:04 AM
