oil cooler in cosssie?
Old Dec 8, 2010 | 12:12 PM
1cosworth's Avatar
1cosworth
Default oil cooler in cosssie?
anyone uses oil radiator /cooler ?if yes on wot spec
Old Dec 9, 2010 | 03:41 PM
Yes I do, as do loads of others, best done through a sandwich plate with a built in thermostat though, as mine is.
Mine was around 300bhp, but I'd have had one even if it was std power.
Old Dec 9, 2010 | 05:43 PM
1cosworth's Avatar
1cosworth
thanks tabetha !
Old Dec 9, 2010 | 06:36 PM
Hoogi's Avatar
Hoogi
Tabetha........Guessing if you're using a Sandwich plate to run a Cooler then you'll have had to loose the coolant hose that runs from the back left-hade side of the Engine that runs to the oil warmer thing ?
If so what do you do with the hose routing ?
Old Dec 9, 2010 | 08:49 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I just pipe it straight to the head.
Steve
Old Dec 10, 2010 | 10:12 AM
What cossie4i says, that's where it ends up anyway, if a track car where no heater is wanted(though I'd still have one-window demisting) you can simply block water pump outlet to heater and the head input from the cooler.
Brickhouse
14
Oct 3, 2015 07:28 PM
