Changing Morette's back to standard
Old Mar 27, 2004 | 04:50 PM
Default Changing Morette's back to standard
I've noticed that a lot of Escort Cosworths have had the Morette twin headlight conversion, was this something Ford did? Or just a real popular modification to do to an Escort Cosworth?
Is it simple to change the Morette's back to standard headlights?
And by simple I mean if you went to a garage and asked them to do it they'd charge the same or a similar amount to having a standard headlight replaced like for like.
Any help or advice appreciated.
Thanks
Old Mar 27, 2004 | 05:31 PM
THE RADMAN's Avatar
THE RADMAN
ford never fitted them as standard,not too bad to refit normal ones as they use the orig plugs/fittings, just an extra live and earth to remove to do the job properly,the bottom bolts are a tvat to get at though! nick
bigryrs
Mar 28, 2016 09:11 PM
fuzzy
21
Feb 15, 2016 10:26 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
A.t.p
Aug 15, 2015 11:37 AM
track.focus'd
Aug 12, 2015 05:53 PM
