V8 Chevy Sierra Track Car
Old Nov 30, 2010 | 03:58 PM
Shaggy's Auto Store's Avatar
Shaggy's Auto Store
Default V8 Chevy Sierra Track Car
Hi and welcome to my thread, im going to be logging the modifications to my five door Sierra as i continue to prepare it for trackdays.
Brief Spec so far is -
*5.7 Small Block Chevy V8 sourced from an old V8 Euro Car
*Rebuilt Richmond racing four speed gearbox
*Tilton racing flywheel and racing basket clutch kit
*Home made tunel & bulkhead moving engine 12 inches
*Summit Racing 3inch x-pipe exhaust
*Hedman Corvette exhaust headers
*Rebuilt 7.5inch 2wd Cosworth Diff with 909 Crown wheel and Pinion
*330mm Pro Comp discs on alloy bells and four pot calipers upfront
*Escort Cosworth rear calipers and and groved discs
*Leda tarmac rally spec front coilovers and Bilstien rear shocks & springs
*Five Gallon Alloy foam filled fuel cell
*Modified rear axel mounting points, polybushed & alloy beam mounts
*Motor Drive carbon composite bucket seats
*Autometer Recall rev counter and oil / water clocks
*Vauxhall corsa electric power steering with adjustable resistance control
*Quick rack steering kit
*Canton Racing Sump and Morosso Oil pressure Accumulator
*Wilwood floor mounted brake bias pedal box
*Holley Red type electric fuel pump with built in regulator
*Black Diamond braided brake hose kit
*11mm Braided fuel hose
*Adjustable top strut mounts
*Compression strut kit
*3 Door Cosworth grill, front bumper and rear spoiler
*3 inch Racing alloy radiator
*Mallory Racing Distributor and ignition coil kit
*Quick fuel Technology 750cfm Racing Carb Kit
Will add recent pictures shortly, to see progress so far check out my garage
Last edited by Shaggy's Auto Store; Nov 30, 2010 at 03:59 PM. Reason: http://passionford.com/forum/garage/1988-Ford-Sierra-17-ShaggysAutoStore.html
Old May 24, 2011 | 11:47 AM
Joshy's Avatar
Joshy
Dreamer
any updates mate?
how did this slip past me before lol?
really interested
Old May 24, 2011 | 12:31 PM
Joshy's Avatar
Joshy
Dreamer
hope you dont mind me putting up some pictures from your garage.
track.focus'd
Aug 12, 2015 05:53 PM
Vincereese
Aug 11, 2015 08:44 AM
Adam-M
22
Aug 10, 2015 10:46 AM
RIB1122
Aug 3, 2015 09:20 AM
Old ford
Jul 31, 2015 06:50 AM
