MF2 5th Injector & Turbosystems ECU
Selling these as im going cossie management in new year.
1.
MF2 injector driver, comes with loom (only short so will need extending to relevant points i.e. battery live, etc), erl pressure switch ( I used 3 bar map sensor rather than this but its there all the same), a 803 dark green, a proper braided fuel hose that replaces cold start outlet on metering head and has correct end swaged on to seal on injector top. Comes with injector housing that will need mating to your crossover. Wanting £240 or nearest offer, hardly been used in fairness, done 2000 miles tops since I got it.
2. Series 1 ecu (i.e. no knock sensor- the one to have really) with turbosystems chip in it. Also other ecu with 7200rpm rev limit mod to it. Both carried out by turbosystems for my NMS engine. Say £150?
can be picked up from pontefract or posted at cost.
1.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
mk3ste
Oct 17, 2021 10:09 AM
