Clutch slip
I have a ap paddle clutch that was previously fitted to another car that had done less then 1000 miles. Fitted the clutch and went for a drive and the clutch slips in the mid range power and even in 5th gear when you poke your toe down. The only thing that is going through my mind is that i may have put the plate in the wrong way round. Would this make the clutch slip or just ride high? I had the fly wheel refaced and de-geased before i installed it.
Thanks
Thanks
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
