Saph heaterbox..
Old Nov 23, 2010 | 12:06 PM
R5FORD's Avatar
R5FORD
Default Saph heaterbox..
I fitted my 3dr heaterbox back in my car and it didnt run.. I had a spare sah heaterbox and wired that up.. Now it works for all of 30 seconds before it blows the 15amp fuse when i touched the fuse it was burning hot.. Does the saph heater box run a higher amp fuse? So can someome tell me what amp fuse there heater uses
Old Nov 23, 2010 | 12:36 PM
jon@work's Avatar
jon@work
Last time I measured the current draw of my saff heater motor, it settled at about 14A, so the standard 30A fuse as fitted to saffs is a little excessive, but Ford thought it was OK.
Old Nov 23, 2010 | 12:42 PM
martysmartie's Avatar
martysmartie
Mk2 heater is 30A, is Mk1 15A then?
Martin
Rsmat
89
Oct 12, 2015 07:50 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
landaqmabba
Sep 15, 2015 07:16 PM
