Drilling out/removing spot welds?
Old Nov 21, 2010 | 05:18 PM
mattseries2's Avatar
mattseries2
Default Drilling out/removing spot welds?
How do i go about doing this?
Trying to remove my battery tray
Old Nov 21, 2010 | 05:24 PM
foreigneRS's Avatar
foreigneRS
Testing the future
buy a special spot weld drill bit. there's 2 types commonly available.
Old Nov 21, 2010 | 05:27 PM
vinnyvangough's Avatar
vinnyvangough
I was looking at getting a set of spot weld drill bits to drill spot welds. Couple of my mates said that they are not worth getting and just use a normal drill bit, but others say they are well worth having. So look forward to any reply's to your post
Old Nov 21, 2010 | 05:30 PM
mattseries2
I brought one and it was wank! Waste of £7!
Old Nov 21, 2010 | 05:37 PM
S1's Avatar
S1
As foreigner RS says there are two types. One is like a small hole cutter which cuts around the spot weld. Ive never used this type as it leaves metal to grind/clean up after. I use the type which is like a normal drill bit but flat on the end with a centre pip. I centre punch the middle of the spot weld first. These type remove the spot weld from the top panel. With a bit of practice you can leave the bottom panel undamaged ready for a new panel to be welded on. You have to be careful not to overheat them as they will blunt very easily but can go on for ages if used properly.
Old Nov 21, 2010 | 05:43 PM
vinnyvangough
Something like this?
http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
Old Nov 21, 2010 | 05:47 PM
S1's Avatar
S1
Originally Posted by vinnyvangough
They're the ones i dont use.
These are the ones I use.
http://cgi.ebay.co.uk/SYKES-PICKAVAN...item588af13f83
Old Nov 21, 2010 | 06:41 PM
Turbosimpsons's Avatar
Turbosimpsons
the flat one's are great. iv'e used them loads of times they are the best one's for the job.
Old Nov 21, 2010 | 06:49 PM
vaughant's Avatar
vaughant
Got to disagree there chap,the ones with a claw are much better,but you really need to give them a good hole punch first as a guide as they can move around a bit otherwise.
Nothing wrong with the other type but I'm definitely converted after using the spring loaded claw ones!!!
I like the fact that they leave a little bit of metal behind as it a lot easier to weld the new panel too after you've drilled the holes.
Old Nov 21, 2010 | 06:59 PM
botters's Avatar
botters
competant bodger
+1 far better way of removing spot welds
Old Nov 21, 2010 | 07:09 PM
foreigneRS's Avatar
foreigneRS
Testing the future
where did you bring it from?
Old Nov 21, 2010 | 07:24 PM
cossiecrew's Avatar
cossiecrew
[quote=S1;5196698]
http://cgi.ebay.co.uk/SYKES-PICKAVAN...f83[/quote]
im in the crash repair trade and use these everyday
Old Nov 21, 2010 | 08:06 PM
mattseries2
screw fix
Old Nov 21, 2010 | 08:20 PM
vaughant's Avatar
vaughant
Got the claw one from machine mart.
Old Nov 21, 2010 | 08:38 PM
foreigneRS's Avatar
foreigneRS
Testing the future
screw fix
did you buy it from there as well?
Old Nov 21, 2010 | 08:42 PM
mattseries2
Old Nov 21, 2010 | 08:48 PM
vinnyvangough
[quote=cossiecrew;5196990]
Originally Posted by S1
Just bought one. I'll give it a go and see how it goes. Gotta remove some Mk6 Escort wings
Old Nov 21, 2010 | 08:52 PM
foreigneRS's Avatar
foreigneRS
Testing the future
buy - bought
bring - brought
Old Nov 21, 2010 | 08:58 PM
mattseries2
buy - bought
bring - brought
Very sorry!
Knew what i ment!
Old Nov 21, 2010 | 09:01 PM
foreigneRS's Avatar
foreigneRS
Testing the future
did you mean 'meant'
Old Nov 21, 2010 | 09:03 PM
mattseries2
boeb
Jan 9, 2020 05:11 AM
bobsworth
77
Mar 24, 2016 09:30 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
