Cosworth managment.....coil on plug??
Old Nov 21, 2010 | 12:29 PM
creator's Avatar
creator
Default Cosworth managment.....coil on plug??
Hi chaps as above can coil on plug be used with cosworth management?
Old Nov 21, 2010 | 01:57 PM
foreigneRS's Avatar
foreigneRS
Testing the future
not as standard, you need to have a driver (wasted spark is commonly available) installed into your ecu.
Old Nov 21, 2010 | 02:28 PM
creator's Avatar
creator
hi mate cheers for that, i should have stated i will have a pectel board and wasted spark driver in the ecu, but really just want to know if you can use the coil on plug and how would you wire them up?
Old Nov 21, 2010 | 02:44 PM
wes's Avatar
wes
With 2 ignition outputs provided by the wasted spark driver you could use COP but they would only work when used in wasted spark configuration i.e. coils 1 + 4 would fire at the same time, as would 2 + 3. You would use a 4 channel ignition module like the Bosch 0227 100 211 and wire it up like this:
However I couldn't confirm 100% if that module will work with a weber ecu, as when i tried the 2 channel version with my old wasted spark setup on my old L8 with wasted spark driver it didn't work, same setup on my Autronic SM4 and it worked startight away!
Old Nov 21, 2010 | 03:26 PM
creator's Avatar
creator
Aahh cheers for that wes thats brilliant.ill try and do some more digging
Old Nov 21, 2010 | 03:53 PM
ECU Monitor Enthusiast
You ,must have wired it up wrong then...
I suspect you didnt earth pin 24 on the ECU ...
Old Nov 21, 2010 | 04:22 PM
creator's Avatar
creator
Simon what ignition module can be used?and what cop?
Cheers for your input
Old Nov 21, 2010 | 04:49 PM
wes's Avatar
wes
I think you'll find I did try that along with a few other things YOU advised me on at the time Simon I only recently deleted the PM's from you as well
SmudgerByName
52
Jul 28, 2016 06:14 PM
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
jay030787
Sep 18, 2015 07:34 PM
Roosie
Aug 15, 2015 08:09 PM
Aug 14, 2015 07:29 AM
