Mapper Gurus help with swapping injectors.
500bhp Cosworth in making
on a cosworth yb running greys/P8 ecu
its mapped perfect at the min but need to swap injectors from bosch greys and want to go 63lbs siemens.
what will happen to the car would it start? Run? get me to a mapper?
obviously i know i need to get it mapped but didnt know if it was overfuel or underfuel.
cheers
cheers
someone must have a mapp from someone else's car with similar engine mods/injectors etc. then lower your boost right down. Just need to copy the data onto your chip and it should be fine if you then get it mapped properly i would of thought ? ill be corrected if im wrong ?...
but as above much easier to change when your with the mapper.
Well it would over fuel as the ecu will keep the bigger injectors open for the same time as it would the greys. ECU has no knowledge of what injector is in there and will just do what it was told to do.
when i did this on mine i got reyland to send me a base map chip to run around on.. chip was 150 and then when in for mapping the price of the chip was knocked off the mapping.. dont know if all tuners are the same..
Greys 0 280 150 403 are 47.9lbhr, with them being used they will no doubt flow slightly more than this, so even nearer to the 63's, but still lean, just stay off the boost.
I must agree though why bother, nothing wrong with greys if correctly mapped, but from what I've heard it isn't anyway, certainly not cold running anyway.
Siemens/Deka 63`s are on another planet resolution wise, compared to a grey..... Don`t get me wrong greys are a cracking injector but the technology is ancient compared to new stuff....
Greys are very close flow wise to a 55 so it should run with 63`s to do a short distance...... Have you got an AFR guage so that you can check it ?
I don't doubt for 1 second siemens are a easier more controllable injector I just don't see the point of ditching perfectly good useable injectors, that can still give ace emissions and performance, my greys had enough resolution for a mot pass and 100% perfect running at 0.97% CO, 137ppm with 200,000 mile son at the mot test, and was NOT adjusted for the mot, and was NOT on closed loop.
For once I agree with Tabs..LOL
Nothing wrong with greys in all operating conditions.
Its more down to most mappers not understanding or not able to adjust all the correct/required parameters in the weber ecu's that gave them a bad name.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
grishenko45
Sep 9, 2015 12:58 PM
