No Dipped Beam on Escort
Old Nov 19, 2010 | 01:52 PM
starlored's Avatar
starlored
Default No Dipped Beam on Escort
I have an odd ? Problem I have no dipped beam on the passenger side of my 'M' REG Escort, I have checked and changed the Bulb and the fuses all appear OK.
What I have found is there is no power to the white plug that sits on the bulb, all the side lights work, Indicators and High beam work.
Could the problem lay with a relay only thing I have not looked at, any help would be appreciated
Old Nov 19, 2010 | 08:12 PM
NO, relay will supply both lights, so you'd lose that beam on the other side also, most likely a break in the wire, or a bad connection, just probe along with the test light till you find it.
Old Nov 21, 2010 | 09:40 PM
jamie's's Avatar
jamie's
prob may lie in the fuse box,
very common prob on these cars, easy fixed if you trace it back
Old Nov 21, 2010 | 11:07 PM
martysmartie's Avatar
martysmartie
I would be inclined to agree with this check the live for a break.
Martin
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
