HELP
Can you help i'm putting a 2wd cosworth gear box in to a 4x4 cosworth has anyone got pics and info on how to mod the gear box cradle as the 2wd one dose not line up cheers
If it has a 4x4 tunnel like is suspect it does you will need to weld in a little bracket for the 2wd craddle to fit..
There is a steel craddle witch is a direct fit but i cant remember the fins code,someone must know it???
cheers danny
cheers danny
what about the other way round? i have a 2wd 3 door converted to 4x4 with the biggest bodge of a cut n shut gearbox mount you will ever see lol! is there any direct fit mount available for mine?
iv got a 2wd tunnel with a 4x4 gearbox in it on my FOCOS and iv had to redrill the 4x4 bean to make it all line up right
and befor i drilled the beam that holps the gearbox
