S2 RST Brake Set Up's
Old Jan 28, 2005 | 10:22 AM
Sheldy's Avatar
Sheldy
Default S2 RST Brake Set Up's
I was just wondering what sort of set ups any of you guys prefered and/or had good experiences with.
I'm currently using standard caliper and cossie front discs but as these are starting to warp i was thinking about changing to a different set up any body got any ideas?
I dont really want to blow a fortune as the car is really only a back up to my cossie which i'm currently rebuilding.
Old Jan 28, 2005 | 10:32 AM
Cawood's Avatar
Cawood
i use 4x4 calipers n discs, but ya best bet is the focus ST170 set up
300mm discs and brand new calipers for bout £300 off someone on this site (mite be gadget)
u will need 16" alloys tho cos they wont fit behind 15's
mucho better than the cossie set up
Old Jan 28, 2005 | 11:31 AM
bassboy's Avatar
bassboy
i have got the st170 setup on mine and its brilliant! even braking from 130 with no movement whatsoever! no warping discs or nething either
bassboy
Old Jan 28, 2005 | 04:44 PM
Sheldy's Avatar
Sheldy
think i'll go for the st170 set up then, any other parts needed such as spacers, brachets etc?
Old Jan 29, 2005 | 09:22 AM
adamS2RST's Avatar
adamS2RST
I have the ST170 setup to go on mine too
Old Jan 29, 2005 | 05:32 PM
Stoo's Avatar
Stoo
Ive got Hi-Spec 4Pots but if i were to change id go down the ST170 route
Escortdriver1
Nov 1, 2015 07:55 PM
FlashRS
Aug 30, 2015 08:07 PM
Steve Escos
Aug 24, 2015 07:56 AM
Aug 10, 2015 12:08 PM
dlwarrior
Aug 5, 2015 10:19 AM
