My Escort Cos engine rebuild project*EDIT* she now RUNS....
Old Jan 28, 2005 | 10:17 AM
Turbo lag's Avatar
Turbo lag
Default My Escort Cos engine rebuild project*EDIT* she now RUNS....
Hi started it in june this year but have spent all year buying bits and planning it.
here is the old engine before we took it out.
and here is the car in the garage with the engine out.
Big Andy W trying to work out were the bits go!
Here is the bottom end nearly finished.
will post more pictures when I get the engine in.
Dave.
Old Jan 28, 2005 | 12:39 PM
rsdene's Avatar
rsdene
Good luck with it mate hope all goes well !!!! what spec you re-building to ???
Old Jan 28, 2005 | 01:08 PM
Lee Reynolds's Avatar
Lee Reynolds
that garage is almost as untidy as mine
Good luck wi it mate
Old Jan 28, 2005 | 05:36 PM
Spiky's Avatar
Spiky
what happened dude???
hope the rebuild is soon and you get to rag is soon
Old Jan 31, 2005 | 07:10 PM
Turbo lag's Avatar
Turbo lag
Fitted uprated engine mounts today.
long way to go
Dave.
Old Jan 31, 2005 | 08:21 PM
luke89's Avatar
luke89
Team HOTHOT!
lookin good so far mate good luck
Old Feb 1, 2005 | 05:50 PM
Turbo lag's Avatar
Turbo lag
Fitted fans and new S/S rad pipe to new radiator with S/S nuts and bolts.
still no engine work
Dave.
Old Feb 2, 2005 | 12:28 PM
Glenn5's Avatar
Glenn5
very nice proper job, goodluck with rebuild m8
Old Feb 2, 2005 | 05:43 PM
Turbo lag's Avatar
Turbo lag
putting sump on tommorow and then installing the bottom end in the car from the top
Dave.
Old Feb 3, 2005 | 09:35 PM
Turbo lag's Avatar
Turbo lag
Put sump on tonight
engine ready to go in
and engine in
only took us a couple of hours to install the bottom end, front dif,power steering rack,front crossmember and cross shaft
big thanks to Big Andy W for helping me get it back together.
Dave.
Old Feb 3, 2005 | 10:21 PM
maxest's Avatar
maxest
Look very well Dave keep up the good work!
Old Feb 5, 2005 | 08:02 PM
Turbo lag's Avatar
Turbo lag
fitted starter motor, front dif prop, engine mount heat shield.
porting(matching) the inlet manifold to my ported head tommorow
Dave.
Old Feb 6, 2005 | 09:22 PM
Turbo lag's Avatar
Turbo lag
Finshed the inlet manifold and plenum chamber today, now off to the powder coaters tommorow
Dave.
Old Feb 6, 2005 | 09:35 PM
CozzyBrom's Avatar
CozzyBrom
Dave.
dont take this as a dig make up your own mind
but do not run that lash up of a rad pipe
cut and welded at 90 degress will cause cavitaoin and air bubbles to form you need a nice sweeped turn
i know making things yaself is a good idea but that aint right way to do it
other stuff looks mint thow good luck
Old Feb 7, 2005 | 11:03 PM
Turbo lag's Avatar
Turbo lag
Hi Brom I didn't make it myself, I wish I could make one
I bought it off Lee at fusion and wasn't aware it was a bad design
what do you mean by "cavitaoin" I have never heard that before.
Dave.
Old Feb 8, 2005 | 09:37 AM
CozzyBrom's Avatar
CozzyBrom
basicly it will creat a swirl in turn sort of causes a blockage
its hard to explane
Old Feb 9, 2005 | 04:43 PM
Turbo lag's Avatar
Turbo lag
you have got me worried now I am using a swirl pot though so maybe it will cancel it out .
Dave.
Old Feb 9, 2005 | 05:43 PM
CozzyBrom's Avatar
CozzyBrom
no mate the water going threw the 90 degree bend will swirl round and try to come back on its self so to speek
not make a blockage but will slow the flow down a little
not a major issue but stick to normal one or get one rolled so its a nice flow
Old Feb 9, 2005 | 06:17 PM
whitneyd's Avatar
whitneyd
Cavitation can also creat air bubbles and that's not good for cooling. Get it with a bend.
Old Feb 9, 2005 | 09:38 PM
Turbo lag's Avatar
Turbo lag
I don't suppose Lee at Fusion will give me a refund
Old Feb 13, 2005 | 08:38 AM
Damo V's Avatar
Damo V
hope you remembered to put the clutch on
Old Feb 15, 2005 | 08:01 PM
Turbo lag's Avatar
Turbo lag
Fitted this today, ready for when I fit the new fuel rail and hose's
Dave.
Old Feb 28, 2005 | 09:03 PM
Turbo lag's Avatar
Turbo lag
Fitted new map sensor bracket.
my new fuel rail arrived last week very bling !
putting head on this week.
Dave.
Old Feb 28, 2005 | 09:22 PM
Lee Reynolds
Old Mar 1, 2005 | 11:18 AM
Glenn5's Avatar
Glenn5
nice fuel rail m8 very bling where did u sorce it from?
Old Mar 4, 2005 | 10:25 PM
Turbo lag's Avatar
Turbo lag
It was my old one that I got modified by a friend, and he did a great job
Dave.
Old Mar 10, 2005 | 04:27 PM
Turbo lag's Avatar
Turbo lag
Head now on just the little jobs to do now
cheeRS Dave.
Old Mar 28, 2005 | 07:20 PM
Turbo lag's Avatar
Turbo lag
Hi long time no post anyway she runs
had a bit of trouble with a air lock in the oil pump but fixed it with an electric dril on the aux shaft
heres a couple of pics.
just got a few things to put back on the engine bay and to run it in and its away to be mapped and 400 bhp here we come watch out Spiky
Dave.
Old Mar 29, 2005 | 06:50 AM
Looks very nice
Old Mar 29, 2005 | 06:53 AM
Sticky.'s Avatar
Sticky.
Very nice mate
Old Mar 29, 2005 | 05:17 PM
sviet's Avatar
sviet
where you buy this cam vernier
Old Mar 30, 2005 | 05:19 PM
Turbo lag's Avatar
Turbo lag
I would tell you, but they aren't that good and I would not recommend the retailer he is a moron.
You can't see from the picture, but they are different colours - one has a matt finish and the other has a shiny finish plus there is a lot of pitting in the finish on the shiny one. I was well disappointed.
I only fitted them because I had to send them back a couple of times due to other things wrong with them and I ran out of time.
I will take them off next winter and get them re-anodised.
Old Mar 30, 2005 | 05:50 PM
DaveEscos's Avatar
DaveEscos
Dave
how did you fit the engine?
did you have the cossmember all fitted up and dropped the engine in witht he diff attatched?
how did you get it on to the gearbox?
as much info as poss mate as ill be doing this soon
Old Apr 1, 2005 | 09:14 PM
markk's Avatar
markk
Turbo lag,
whos going to be mapping it ?
Old Apr 2, 2005 | 10:09 AM
Turbo lag's Avatar
Turbo lag
Hi Dave
Like in my pictures I had to drop the crossmember down so I could lift the block out from the top, so I had to do the reverse to get it in.
it went in ok but we had to get the engine on the gearbox and lower and wiggle it a bit at a time till it went on.
also we fitted the dif and other bits after.
Dave.
Old Apr 15, 2005 | 07:16 PM
Turbo lag's Avatar
Turbo lag
Done 420 miles 580 to go
Old Apr 15, 2005 | 07:24 PM
Victor's Avatar
Victor
That looks very very nice
Vincereese
Jun 1, 2023 09:14 AM
Carlbacciochi
24
Jun 30, 2016 04:31 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
track.focus'd
Aug 12, 2015 05:53 PM
