roller bearing t4, 44mm tial wg & manifold?
Old Nov 15, 2010 | 07:00 AM
B13 JUS's Avatar
B13 JUS
Default roller bearing t4, 44mm tial wg & manifold?
what would the above parts worth?
the roller bearing t4 has a 4" polished front housing, a .82 ex housing and i've had a adaptor plate made so you can use a normal 3 bolt exhaust clamp and i still have the 3" v band but the exhaust needs modifying for this.
Reyland 2wd exhaust manifold trouser section with
44mm tial wastegate and screamer pipe
Old Nov 15, 2010 | 08:15 AM
derekd's Avatar
derekd
all depends on how much u want
650 for the turbo and around 250 for wastegate and section
Old Nov 15, 2010 | 08:22 AM
nuttynil's Avatar
nuttynil
RS nutta
How about a price ..
Old Nov 15, 2010 | 10:40 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I think the turbo has got to be worth well over £800
How many miles has it done ?
Steve
Old Nov 15, 2010 | 11:37 AM
BIG WULL's Avatar
BIG WULL
Fae the Dale
1k the lot!
mmm very interested..
Old Nov 15, 2010 | 11:50 AM
B13 JUS's Avatar
B13 JUS
Steve
about 2k, still as new
Old Nov 15, 2010 | 12:05 PM
B13 JUS's Avatar
B13 JUS
have you no read my first post?
i know it would cost well over 2k new to buy but not sure what to ask for.
B13 JUS's Avatar
B13 JUS
Originally Posted by BIG WULL
1k the lot!
yhpm
Old Nov 15, 2010 | 04:15 PM
Dicko&Vacant's Avatar
Dicko&Vacant
What you going for now mate
Old Nov 15, 2010 | 05:03 PM
B13 JUS's Avatar
B13 JUS
after speaking to vince @ cr turbos today i think i might be keeping it now
Old Nov 15, 2010 | 05:40 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Liar, you,re getting a TT T38 with a 70mm Airtec intercooler
Steve
Old Nov 15, 2010 | 05:44 PM
Staffi's Avatar
Staffi
Sell it to Steve and i'll buy his T38
Old Nov 15, 2010 | 05:51 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
I think that T4 will split his block straight down the middle
Steve
Old Nov 15, 2010 | 10:19 PM
B13 JUS's Avatar
B13 JUS
Steve
I was going to try the gt3076 after seeing the results what mark is getting from them but Vince said there will be no difference in spool up and the t4 is much stronger, rebuildable and should make the same power if not more.
Old Nov 15, 2010 | 10:46 PM
Danny @ Enhanced Performance's Avatar
I disagree mate,dont forget the results they got on dougs car was with a 3071!!with a 3076 i rekon more like 560+hp and over 500 lb ft..
The t4 you have is strong but for spool with the right set up the 3076 will be better..
cheers danny
Old Nov 15, 2010 | 11:33 PM
andy130's Avatar
andy130
cheers danny
danny how would a G30/76 last on say a 550bhp? on a car that is worked hard?
Old Nov 16, 2010 | 04:14 AM
B13 JUS's Avatar
B13 JUS
cheers danny
Do you not think my rb t4 with the .82 exhaust housing would make the same power?
What would be the difference in spool Danny?
Vince said he knows a few people who tried them and gone back to the rb t4.
Old Nov 16, 2010 | 06:43 PM
Iv never had any probs with any of the gt series turbos mate at high boost levels..
Iv used a couple of the rb t4s before justin and they just dont feel as strong from low down and through the midrange like the gts do..
It will make the same power but not the same spread of power and i dont know anyone to go back to one after a gt series turbo..
I deal alot with vince and do trust what he says as he knows his stuff but its all down to how your engine is specced to how the turbo performs and after what weve discussed on your engine the gt series will work better imo..
cheers danny
89barto89
Oct 4, 2015 06:59 PM
fordrallycar
Sep 30, 2015 07:57 PM
20/20 vision
Sep 28, 2015 03:03 PM
caprixpack
Sep 25, 2015 07:53 PM
