mk1 frs power steering now with pic
went to go out in the frs today, started the car went to pull away no steering at all, got out the car to a puddle of fluid, after havin a look the pipe that comes out the bottom of the pump has came out
, is there anyway to fix it or do i need a new pump, will get pics tomorrow as its to dark just now.
cheers garyf
wentto go out in the frs today started the car went to pull away no steering at all, got out the car to a puddle of fluid, after havin a look the pipe that comes out the bottom of the pump has came out
cheers garyf
_________
, is there anyway to fix it or do i need a new pump, will get pics tomorrow as its to dark just now.cheers garyf
_________
easy and very cheap fix
Ford sell a new nut joint that just pushes on the end of that pipe. then just screw the new nut back into the pump.
It should cost you no more than Ł10
Na mate, exsactly the same as a transit RWD!
the nut is clipped to the pipe and the clip fails.
Ford sell a new nut with a stronger interal clip. It litrally pushes on the old pipe and bolts back it to the pump.
10mins, jobs a gooden
Oct 9, 2015 07:38 PM
Ben26
Aug 27, 2015 08:56 PM
track.focus'd
Aug 12, 2015 05:53 PM
