Focus Estate MK2 rear lights
Hi guys,
I'm trying to replace LHD rear lights on MK2 estate with RHD ones but not to sure how to go about swapping the fog light with reverse. On some models the wires for both are fitted to both sides in the wiring loom so the appropriate lamp unit just connects to the wires needed. Is it the same case with Focus? If not have you got suggestions how to change them without having to rewire the whole lot.
sridgett
15
Aug 3, 2015 07:26 PM
