running prblems
Old Nov 10, 2010 | 01:28 PM
spitch's Avatar
spitch
Question running prblems
Hi i have a p reg escort with the 1.6 zetec running the efi fuel system.
Problem is that when i first start up when cold the car runs very sluggish and if i set off straight away when i come to a stop it cuts out, but wheen warm runs and idles fine. Has anyone got any ideas as to what it could be. also i have just changed the plugs and ht leads and still the same.
Old Nov 10, 2010 | 01:41 PM
martysmartie's Avatar
martysmartie
First I would remove clean and lube (No rhyme intended ) the ISCV as there common for jamming.
If no luck I would check the CTS (Coolant Temperature Sensor) this as the name suggests provides info on coolant temperature to the ECU, from this info one of the things it will do is is open the ISCV (If required) and so the engine runs faster under cold conditions (I.E when starting).
The ISCV sounds as if it's working otherwise you would have no base idle at all, but you can always test when removed by putting 12V directly to it.
Martin
`spotty
Sep 25, 2015 11:41 PM
dombanks
Sep 21, 2015 08:38 PM
tib2220
Sep 14, 2015 12:33 PM
Eigdoog
Sep 13, 2015 05:46 AM
