Pioneer 5 channel car amplifier - Boxed : As new condition £100 *SOLD*
This 5-channel Class-D amplifier sets new standards of excellence with superior distortion-free sound, first-class power and a slim compact package. With 5 channels - 4 analogue and 1 class-D mono - and Low Pass and High Pass Filters, you are able to directly connect 4 speakers and a subwoofer. Efficient Class-D technology needs less distortion-causing input power, so your senses are filled with clear yet extremely powerful sonic pleasure.
Max. output power:
A/B Channel: 4 x 100 W (4 Ohm) +
SUB Channel: 1 x 300 W (4 Ohm) or 1 x 600 W (2 Ohm )
Continuous output power (14.4 V):
1 x 300 W (20 - 240 kHz/2 Ohm),
1 x 150 W (20 - 240 kHz/4 Ohm),
4 x 50 W (20 - 20 kHz/4 Ohm)
Bass Level Control (-22 - +12 dB)
Load impedance capability (2 - 8 Ohm)
Variable LPF (Low Pass Filter): 40 - 240 Hz, -12 dB/Oct
RCA input terminals
RCA input terminals
Was in my Puma for nearly 4 years without missing a beat powering 4 full range speakers and the sub in the boot.
This is a quality product producing an exceptional sound quality. It's got as many crossovers and filters as you could want so it's fully customisable to your own setup.
http://www.hendoncarstereo.co.uk/cgi...d/42/index.htm £375 when new (And now if you can find it)
Boxed - as new condition. Was going to put it in the Mondeo but the sound is ok without it.
£100.
Collection would be preferred from either South Cambridgeshire or North Northamptonshire or as it's about 6kg postage will be about £10.
If collected then I have some cabling as well that I'll include.
matman
Sep 9, 2015 05:45 PM
Aug 12, 2015 09:35 PM
