whining noise
Old Nov 5, 2010 | 06:32 PM
chrisa3's Avatar
chrisa3
Default whining noise
I have just finished building my 2wd cosworth. I bought the car stripped and I have spent 3-4 months restoring it. I got the car running yesterday, but the gearbox was making a loud winning noise. I have checked the gearbox oil and it was empty. Filled it up until the ATF was running out the filler hole. The whinning noise is still there but dissappears when the clutch is depressed. The clutch, bearing etc came out of my other saff and from what I can remember, it wasnt making this noise in there.
The gearbox has sat for around a year. I havent been able to drive the car anywhere yet has it has no mot or tax, and has so far only been idling on my drive.
Is this whinning noise likely to dissapear once I put some miles on it or is it more likely that the bearings are goosed??
Old Nov 5, 2010 | 08:07 PM
Alvyn's Avatar
Alvyn
you might be lucky ie once it has a few miles put on it that the whinning may decrease to a level that you dont mind but once it's whinning it will always whine unless you change the bearings tbh!
Old Nov 6, 2010 | 09:44 AM
As above can only wait and see, running a dry gearbox is not a good idea though.
Old Nov 6, 2010 | 09:51 AM
chrisa3's Avatar
chrisa3
Im hoping its just because the box oil hasnt circulated properly, with it just standing on my drive. Im not holding out much hope, i have had more bad luck than good since starting the car. Maybe its the plate.... F666 xxx
Old Nov 6, 2010 | 10:40 AM
opposite lock's Avatar
opposite lock
lol at the plate better the devil you know haha . At least you will know the whole car by building it up
i,ve recently just put out a wee search on 'G666 WAR' a customer of mine bought it brand new 2wd, was meant to be VAR but when turned up they,d changed it , still out there somewhere
mike
gingeRS
17
Oct 2, 2015 09:42 AM
Botts
Sep 22, 2015 02:04 PM
Ronnie Scott
Sep 20, 2015 10:21 PM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
rsturbo27
Sep 5, 2015 05:08 PM
