Servicing Electrics...
Old Nov 4, 2010 | 12:54 AM
Chopshop85's Avatar
Chopshop85
Default Servicing Electrics...
How often do you change out your spark plugs/leads?
I have a groupA coil and a set of "fordmotorsport" leads that are a few months old. My car has developed a bit of a misfire when boost is around 13psi?
Old Nov 4, 2010 | 01:29 AM
botters's Avatar
botters
competant bodger
should last for years mate, id check dizzycap rotor arms and plug gaps first
Old Nov 4, 2010 | 01:30 AM
Chopshop85's Avatar
Chopshop85
Thats what I was thinking. The plug gaps were done when it was set up. I'm gonna give it a once over 2moro.
It just seems odd that yesterday it suddenly developed this misfire.
Old Nov 4, 2010 | 01:17 PM
stevo123's Avatar
stevo123
Sometimes plugs can go bad, you usually notice is it immediately when they are fitted or within a very short time. As above check cap/rotor and if no faults found change for another set of plugs.
Old Nov 4, 2010 | 01:39 PM
Chopshop85's Avatar
Chopshop85
Managed to have a good look in the daylight today. The dizzy cap at some major crusty build up on the points. I was almost certain I Checked in when I fifted my new splash gaurd afew weeks ago. I must have not lol.
Old Nov 4, 2010 | 01:46 PM
chaffe's Avatar
chaffe
Turbocharging Technician
With regard to an ignition problem ialways cange plugs and leads together and gap them accordingly at the same time, also change to distributor and rotor arm if the car has one, quite often you can damage the leads if you only change plugs or vice versa
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Fudgey
21
Sep 30, 2015 06:19 PM
stevecfrst1
Sep 30, 2015 05:18 AM
