which intercooler
hello guys,i need a new intercooler for my cosworth as its for a escort cosworth which i have on now and the boost pipes are not lining up proply,ive seen some rs500 style 1s on ebay but some have 76mm inlet and outlet and some 1s with 60mm inlet and outlet,also will i need diffrent size boost pipes with my car having a t34 turbo,cheers lads and sorry if this has been asked before.
cheers
cheers
As above airtec RS500 are excellent value for money and work well into the bargain, the outlet from the intercooler could be better aligned, but can be used without adaption, just if airtec gave a shit and moved it a few mm, fit would be 100%, but they don't seem that bothered.
nice 1 cheers lads.what about these intercoolers on ebay
http://cgi.ebay.co.uk/FORD-SIERRA-RS...item1e5f63bb59
will this be any good.cheers
thanks for the reply again mate,power wise am hoping for arounf 350 bhp with a t34.63, 3 bar, msd stage 3 chip,siemens injectors,low comp pistons,would the intercooler in the link be enough for my power estimate,
cheers
cheers
Intercooler will be plenty good enough, to go with your very odd spec engine!!
if wanting 350 keep the std compression, and the std .48 housing.
No point imo making it laggy with lower cr and bigger turbine, a t34.48 will happily do 350 all day long.
Up to you what chip you use, but there are others, I much prefer GGR, a few basic things to check and off you go.
