How many miles from new turbo?
Old Nov 3, 2010 | 07:58 AM
chaffe's Avatar
chaffe
Turbocharging Technician
Default How many miles from new turbo?
As title, how many miles would you expect to get from a new t34 turbo or similar before it needs a re build? just re built mine after 12,000 reasonably hard miles running 1.1 bar boost.
Old Nov 3, 2010 | 08:15 AM
Rax's Avatar
Rax
I wouldnt be impressed with that tbh .My crabby standard T3 has done more miles than that at 1.6bar and its still perfectly fine .
Old Nov 3, 2010 | 08:25 AM
chaffe's Avatar
chaffe
Cool, i just wanted to get an idea, it has a t3 cartridge so i wonder if t34s last a little less as they are under more stress having a bigger rotating mass? The t3 internals are much lighter i think. I used to drive the car flat out for 10 miles to pick my ex up, and then flat out back on some country roads almost daily, as well as all the usual running around,(mostly on country roads and hard!)
Old Nov 3, 2010 | 08:53 AM
Rax's Avatar
Rax
I dont know a great deal about turbos but I would hope it lasted a lot longer than that especially running such low boost.Dosnt seem right to me tbh,as long as you cool it down after you have kicked its head in that is
Old Nov 3, 2010 | 08:58 AM
chaffe's Avatar
chaffe
lol, it did only cost 150 quid mind you! i machined a new bearing last night and re built it, its going to a mate now in exchange for some big injectors! deals
Old Nov 3, 2010 | 07:16 PM
1.1 bar is not high at all, should last loads longer all being well.
The T3 and T34 core/bearing housing are 100% identical.
I ran 18 psi for well over 40,000 miles and show no signs of undue wear, on a T3-34
Old Nov 3, 2010 | 08:29 PM
chaffe's Avatar
chaffe
it was also worth pointing out only ONE bearing was worn, the exhaust side, maybe due to not spooling the turbo down after hard use? or maybe egt's were too high effectivly cooking the oil on that side. Its fixed now and swapped for some nice big injectors lol
Old Nov 4, 2010 | 08:14 AM
I always cool mine down by running the last mile or so high gear little load prior to switch off.
Old Nov 4, 2010 | 08:18 AM
JonnyBravo's Avatar
JonnyBravo
My mate ran his T34.55 peaking at 30psi for probably 20k, the car was then sold and its still going strong. Infact the turbo wasn't new when he got it as the engine was built for the previous owner by SCS so it had seen some use before he owned it, just not as much track use which is what he mainly used it for.
Old Nov 4, 2010 | 09:48 AM
chaffe's Avatar
chaffe
without a doubt the best way mate, better than letting it tickover thats for sure, sometimes you just cant be arsed though, especialy when the turbo only cost 150 quid new lol
Old Nov 4, 2010 | 09:49 AM
chaffe's Avatar
chaffe
thats good going, is it a water cooled core?
Old Nov 4, 2010 | 09:55 AM
JonnyBravo's Avatar
JonnyBravo
Yes it was and still is.
Such a good engine that one, not mega power by todays standards but just takes all the abuse you give it
Old Nov 4, 2010 | 09:59 AM
chaffe's Avatar
chaffe
Ah mine is oil cooled only, and was on a ZVH which, like a cvh is living in its own camshaft filings lol
SmudgerByName
52
Jul 28, 2016 06:14 PM
Matt Baxter
Sep 16, 2015 08:30 PM
Ben26
Aug 27, 2015 08:56 PM
jaimesdna
Aug 25, 2015 06:59 AM
Michael Wisbey
Aug 14, 2015 11:57 PM
