Fiesta RS1800 ignition
Old Nov 2, 2010 | 10:25 AM
Maxxter's Avatar
Maxxter
Default Fiesta RS1800 ignition
Hello!
I have ingition problem with my RS1800. I bought new Motorcraft sparks, new spark cables too. It worked well for few weeks and now only 3 cylinder work. I screwed off the sparks and two of them was broken. So I want to try other type of spark. Has anyone an experience with other types?
Thanks!
Old Nov 2, 2010 | 01:27 PM
martysmartie's Avatar
martysmartie
What do you mean by two were broken, I.E physically or just not working? If the latter i suggest they were either dodgy plugs or somethings wrong elsewhere, I.E getting to hot etc.
Martin
Old Nov 2, 2010 | 04:39 PM
Maxxter's Avatar
Maxxter
Martin
The ceramics was broken, so I think it didn't work well.
Old Nov 2, 2010 | 05:39 PM
Razer's Avatar
Razer
I always use NGK, also used motorcraft, but it didn't feel right when fitted
If the ceramics is broken, just be gentle
Old Nov 2, 2010 | 06:10 PM
Plugs don't break physically for no reason, try as said being more gentle, I've not broken a plug in over 30 years, when done correctly and this includes plugs so stuck they took the threads out of heads!!
Old Nov 2, 2010 | 07:26 PM
Maxxter's Avatar
Maxxter
I don't know why, but I screw it easily and also easy to screw off the sparks.
sridgett
Oct 1, 2015 07:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
Marv888
Sep 26, 2015 03:44 PM
