WANTED Ford focus st170 inlet cam
its fine to run with the lugs snapped off, ford technicians and local greasemonkeys snap them off all the time when doing belt changes, the key is to NOT use the lugs to hold the cams whilst you loosen the cam pulley bolt!!
Might make it a bit trickier to time it up thats all will be fine
track.focus'd
Aug 12, 2015 05:53 PM
gordyshreds
20
Aug 10, 2015 02:59 PM
