Crank Position Sensor Bracket Pics
Old Nov 1, 2010 | 11:02 AM
Mk1 Mex's Avatar
Mk1 Mex
Series One
Default Crank Position Sensor Bracket Pics
Hi all,
Starting to get all the parts etc together to convert from MFI to management.
I would prefer to make/build most of the stuff my self but after numerous searches etc i cant find any detailed pics / Measurements of a Crank Position Sensor Bracket.
I'm really just after a measurements if i'm totally honest.
cheeRS
Barney
Old Nov 1, 2010 | 03:59 PM
Karlos G's Avatar
Karlos G
Balls Deep!
If your running standalone management then just fit the EFI flywheel and then drill the hole so that the end of the CPS is perfectly inline with one of the 'teeth' on the back of the flywheel!
Old Nov 4, 2010 | 04:38 PM
Mk1 Mex's Avatar
Mk1 Mex
Series One
Karlos,
Cheers mate, but really cant be ar$ed to remove the engine etc again having only just put it all back in.
Barney
Old Nov 4, 2010 | 05:34 PM
Karlos G's Avatar
Karlos G
Balls Deep!
So have you fitted an EFI flywheel but not drilled the block for the sensor?
Old Nov 4, 2010 | 05:55 PM
zippyobrien's Avatar
zippyobrien
is drilling the block easy then ?
i thought it had to be in a really precise position
Old Nov 4, 2010 | 09:34 PM
rickbartlett's Avatar
rickbartlett
G911 TTA
u could make a pickup sensor to run off the top pulley if u havent got an efi flywheel,or so ive read anyway
Old Nov 5, 2010 | 03:26 PM
Mk1 Mex's Avatar
Mk1 Mex
Series One
No i dont have a EFI flywheel.
Going to use a 36-1 trigger wheel on the bottom pulley hence why i'm going to use/make my own CPS bracket.
I did hear that you can run a pickup from the top pulley, but dont want to lose the standard look of the engine bay.
Old Nov 5, 2010 | 04:28 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Ah sorry I thought you wanted to know the dimensions for the stock EFI one! lol
If your making your own then just buy a trigger wheel from www.trigger-wheels.com and weld it to the bottom pulley, then knock up a bracket to hold the CPS where you want it, took me about 30mins to do mine, think I used one oil pump bolt and a sump bolt to secure it in place, really easy mate!
j.hammond1
30
Oct 31, 2021 05:28 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Zoggon
Aug 10, 2015 10:39 AM
lockie
Jul 31, 2015 10:03 PM
