new to the scene.....
Old Oct 31, 2010 | 09:14 PM
dannymc86rscab's Avatar
dannymc86rscab
Default new to the scene.....
need some advice... i have 90 spec xr3i cab, but have been buying bits up on ebay for rs turbo conversion, so far i have got engine (ported & polished big valves etc) t3 turbo, wiring loom, ecu's, manifolds, exhaust, pro alloy intercooler, metering unit, bigger brakes, rs gearbox, baileys d/v most of what i think need, i know most ppl say to get a donor car put them side by side and swap everything over but obv i cant do that as i have no donor car??!! just wondering of what sort of problems i can expect to have if any?? also does it matter being a 90 model and efi changing to mfi turbo.... any trouble or as ill be changing the loom will it not matter? also as i have power hood will i have to start messing about with the looms?? any and all advice would be massively appreciated
Old Oct 31, 2010 | 09:35 PM
1strst's Avatar
1strst
stick with the loom you have and go efi turbo like the fiesta
Old Oct 31, 2010 | 09:36 PM
marky_g's Avatar
marky_g
Fleet Manager
ive just done it check my resto thread go fiesta stuff it bolts in and ecu (ofac) plugs in!
Old Oct 31, 2010 | 09:38 PM
marky_g's Avatar
marky_g
Fleet Manager
http://www.rsbible.co.uk/
check here
Old Nov 1, 2010 | 05:07 PM
dannymc86rscab
oh right, is it too much work to go mfi?? i know need the fuel tank, pump and pipes etc, what is better in your opinion?? will it pretty much be a case of getting hold of a fiesta turbo/xr2i inlet manifold and ofac ecu?? for the efi route? sorry about all the questions just getting abit confused now nowhere near as straightforward as i first thought!!
Rob_DOHC
Jul 8, 2012 09:50 PM
34
Nov 29, 2008 08:23 AM
rs_daz
11
Feb 8, 2007 06:07 AM
jimrs16i
Aug 17, 2006 05:12 PM
