2wd/4wd alloy header tank query?
Are there any consequences running a 2wd alloy header tank in a 4wd Saff? The tank has only 1 large boss at the bottom, with 2 smaller bosses higher up as you know. Can i just connect 1 of these to my swirl pot & the other to the turbo, or do i need the additional larger 4wd boss?
Any views would be appreciated, cheers.
I think the turbo return will be to small on the 4x4 one so will need a mod, as you say the 4x4 is larger, IIRC there is a reducer avaliable for this very reason when people do the opposite and put a 4x4 onto a 2WD.
Martin
Martin
Hi Carl, keepin well, hows yourself?
Back on the road with the Cossie, everyday is an education
as usual
oh how i've missed it
Catch you later, i'm off to start another 'query' post!
as usual
