how to remove the distributor
Old Oct 28, 2010 | 04:16 PM
sundera86's Avatar
sundera86
Default how to remove the distributor
how to remove distributor cap on sierra cosworth 4x4. I want to seal it because i have oil leak from there
same engine http://www.google.bg/imgres?imgurl=h...26tbs%3Disch:1
Old Oct 28, 2010 | 07:28 PM
The base of the distributor has a clamp with a bolt(13mm hex head) through the clamp that bolts into the block, so effectively it's held down, remove this clamp/bolt, and the dizzy comes out by pulling straight up, ensure if on std ecu the phase timing is perfectly aligned when re installing.
boeb
Jan 9, 2020 05:11 AM
Orion_Gav
Sep 29, 2015 04:50 PM
20/20 vision
Sep 29, 2015 11:27 AM
