Newman or Kent Mecanical followers? :-)
Old Oct 26, 2010 | 08:34 PM
Bartheez's Avatar
Bartheez
Question Newman or Kent Mecanical followers? :-)
Hi there...
I have a set of 7 Kent cams mechanical followers (Lost one of them years ago, and never got around to find it :-(...)
Its a big spec Zvh, and i am probably going for a custom Newman cam for my setup.
As i already have a set of 7 Kent followers, it would be far easyer to purchase 1 from Burton.
But are theese any good compared to Newmans?
Cheers - Kasper - Denmark
Old Oct 26, 2010 | 08:56 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Cam and lifters have to be ran in together so you cant use your old lifters with a new cam.
Old Oct 26, 2010 | 09:06 PM
Bartheez's Avatar
Bartheez
Forgot to mention that the lifters are brand new. Only fitted and adjusted. The engine never ran...
Old Oct 26, 2010 | 09:08 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I would still use Newman lifters with a Newman cam as they should be made form the same material and bed in at the same rate.
Old Oct 26, 2010 | 09:13 PM
Bartheez's Avatar
Bartheez
Okay...
You may have a point there ...
Thanks a lot
Old Oct 26, 2010 | 09:17 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Just not worth the risk of metal in your oil if either fail IMO.
Old Oct 26, 2010 | 09:59 PM
javierant3's Avatar
javierant3
If you go for a custom newman cam, I think you must go for newman solid lifters. Newman cams are different material as kent and because that is better not to mix them.
Old Oct 27, 2010 | 04:58 PM
craig rst kid's Avatar
craig rst kid
mate i would go newman never hear bad things about them and have a look at my thread on kent cams will give you a rough idea how good kent are
steve.rst
Mar 15, 2016 08:01 AM
