Negative camber on one Wheel!
Old Oct 24, 2010 | 05:29 PM
Kayble's Avatar
Kayble
Default Negative camber on one Wheel!
Mk1 Focus 1.8. I recently noticed that my front drivers side wheel has really negative camber, its been like that since i bought the car (checked old pics) Since buying, its had new bottom arm, new suspension, new knuckle and hub. but its still negative. What else could it be?
CheeRS
Old Oct 27, 2010 | 07:09 AM
If it defo is really negative, as opposed to just looking like it, something is most likely bent, it's usually the tca, but can also be mounting points bent etc.
I'd start by taking to a proper 4 wheel alignment centre that does read outs of camber castor toe, not a std 4 wheel laser alignment at the likes of quick fit etc, they can if it proves way out have a look whilst on the ramps and see where the problem lies as it should stand out a mile, with a tape measure.
Old Oct 27, 2010 | 07:54 AM
Kayble's Avatar
Kayble
ok thanks very much, i will get that done asap
IainRS1700T
Sep 25, 2015 06:44 AM
pabloXR
Sep 21, 2015 12:42 PM
Karl @ FPT
Sep 21, 2015 11:17 AM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
Adam Graham
Sep 6, 2015 06:04 AM
