Cosworth parts 200 block,.25 crank, diff, 4x4 fuel rail, Greys and more
few bits i have had as spares but are no longer needed.
4x4 inlet cover inc throttle bracket SOLD
Escort cosworth fuel rail £35
Saff fuel level sensor SOLD
2wd steering knuckle, few little splits in the rubber but overall good £20
Grey injectors £100 or i have a spare l6 ecu with chip to run greys and t34 £200 for both
header tanks with caps £5 each
Header tank open to offers
Braided oil feed, brand new, the guy who made mine made 2 so i have this spare SOLD
200 block on std bore, no cracks or damage etc block only SOLD
piston was removed to measure up.
2wd head measures 138.6
has had some repar work around the water jackets but has been used since and was removed from a running engine.
Complete as you see it, cams tappets and valves. SOLD
Crank on .25 removed from the 200 block £200 (pic to follow)
4x4 std size pistons and balanced conrods SOLD
2wd sump in good condition £80
Cosworth racing +.25 4x4 pistons std comp, on std rods, £150 (pic to follow)
Have cosworth stamped on inside (not mahle) SOLD
2wd cosworth diff in good wortking order £150 (pic to follow)
2wd exhaust manifold, both sections £40 (pic to follow)
std bores look fine mate, still have the std pistons in there.
my mate came down and measured them for me and i cant remember the measurement lol
cant see why the .25 wouldnt work
working on your pm now
col
Interested in the greys and the L6.
Pardon my ignorance but can you tell me ballpark power figure you would expect from that combo (along with turbo etc obviously) ie 300, 350, 400. I cant find anywhere that tells me which colour order the injectors go in ie yellow, then green?, then blue?
Also do you know who's chip it is? ie MSD/Superchips/NMS etc
Apologies for questions but best to ask before buying! lol
cheeRS
cheeRS
big_Rad
Sep 15, 2017 09:36 AM
Aug 14, 2015 07:29 AM
