is my alternator on its way out ????
Old Oct 23, 2010 | 04:26 PM
OLDSKOOLRYAN's Avatar
OLDSKOOLRYAN
Default is my alternator on its way out ????
hi everyone,
my car will idle fine but when you turn the heaters/lights/engine fan the engine idle drops and the revs go up and down.
so i did some tests with the volt meter.....
12.24 volts engine off
14 volts engine running
13 volts engine running with heater blower, lights and engine fan.
do you think my alternator is dieing ??
thanks Ryan
Old Oct 24, 2010 | 06:44 AM
OLDSKOOLRYAN
up ???
Old Oct 24, 2010 | 12:06 PM
studabear's Avatar
studabear
sounds normal to me, with everything on like that at idle it will be putting a big load on the alternator, you could always check all connections are clean and tight etc and the belt correctly tensioned just to be safe
Old Oct 24, 2010 | 01:06 PM
OLDSKOOLRYAN
i was thinking the same mate, better to be safe than sorry.
thanks
Old Oct 24, 2010 | 02:10 PM
danzul's Avatar
danzul
those readings look pretty normal to me, the volt meter should read about 14 while the enigine is running at 2000rpm
Old Oct 24, 2010 | 02:12 PM
phil_focus's Avatar
phil_focus
i agree with studabear
Old Oct 24, 2010 | 03:16 PM
Perfectly healthy, check your CO, lean mixes will tend to cause the up/down with load at idle as engine making so little power, but alt sounds healthy.
Old Oct 24, 2010 | 06:09 PM
OLDSKOOLRYAN
thanks i will check the co aswell.
jonfoc
16
Sep 11, 2018 05:35 PM
steve.rst
Mar 15, 2016 08:01 AM
timsrs
22
Sep 24, 2015 08:14 PM
jay030787
Sep 18, 2015 04:38 PM
benw456
Sep 16, 2015 05:27 PM
