non abs brake reservoir where from?
The posh are up!!!
im in desperate need of a non abs brake reservoir for my series 2 as have removed the abs,and doing a engine bay resto.
Where can i get one from?
Your best bet would be to ring around a few breakers/scrappy's mate, or look on ebay.
Worst case scenario, you could just run a small rubber pipe between the reservoir nipples.
Big-Dan.
Big-Dan.
