Identifying exhaust/inlet cams Cosworth 3dr
Old Jan 26, 2005 | 03:46 PM
ricky_3dr's Avatar
ricky_3dr
Default Identifying exhaust/inlet cams Cosworth 3dr
I need to find out the differance between exhaust & inlet cams before i refit them, the cams are standard Ford items, Does LYD 2 & LYD 3 mean anything ? as this is cast into either cam,
Any help is appreciated
Ricky
Old Jan 27, 2005 | 05:50 PM
nicksaph's Avatar
nicksaph
i think the inlet cam has grooves in the bearing journals! or is that just the 4x4 cams?
Old Jan 28, 2005 | 09:30 PM
glurbs's Avatar
glurbs
You are right. Inlet cams have those grooves. They are the same in 4x4, 4x2 and RS
Old Jan 28, 2005 | 10:16 PM
Hectori's Avatar
Hectori
yes. inlet cam have groove in bearing journals.
Old Jan 29, 2005 | 05:40 PM
ricky_3dr's Avatar
ricky_3dr
Thanks guys
CLIVE
Oct 2, 2015 12:58 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
IAN RS2k
Aug 18, 2015 07:51 PM
Aug 14, 2015 07:29 AM
