cosworth bottom pulley remover
Old Oct 21, 2010 | 11:05 PM
SS1's Avatar
SS1
Default cosworth bottom pulley remover
You carn't buy the above from a motor factors or ford
Just a heads up I DONT sell them
hi i am selling a tool for removing the bottom crankshaft pulley.this tool bolts on the 3 holes on the pulley and by winding the bolt in in the middle it pulls the pulley off.i used one of these to do the cam belt on my car and it worked great.please check that your bottom pulley has the 3 m8 bolt holes this tool requires as a friend of mine just did the cam belt on a saph and the bottom pulley didnt have the holes in it.
http://cgi.ebay.co.uk/cosworth-botto...#ht_500wt_1156
Old Oct 22, 2010 | 10:33 AM
The thing to do is when the pulley is off, is to remove the woodruff key, then lap the pulley to the crank nose, this not only removes the rust but makes the surface nice and a minute amount smaller, I use fine valve grinding paste, takes about 10 minutes, my pulley now is a dead snug fit and comes off with 1 finger pressure dead easy, when putting back on smother the crank nose with coppaslip or similar makes it come off perfect next time.
As said though the tools are ace.
Old Oct 22, 2010 | 09:50 PM
AndyPen's Avatar
AndyPen
I followed the advise above - worked a treat
Old Oct 22, 2010 | 10:06 PM
botters's Avatar
botters
competant bodger
i used a gear puller on mine worked a treat allthough i did have to remove the rad and intercooler to get it in then i wet and dryed it with 2000grade paper for a few minutes till it slid on easy
Old Oct 23, 2010 | 04:16 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
i must be luckely all the pulleys ive ever took off slide of easy. put plenty of grease on it when putting it back on.
Old Oct 23, 2010 | 04:32 PM
Toe Knee's Avatar
Toe Knee
mine were easy untill the last one, and gonna be a bitch to remove methinks lol. Making my own one up similar to that one at some point as i dont want to have to remove rad etc to use a puller!! ive got some round metal plates already drilled so just need to get a bolt the right size and weld a nut to the middle of the plate!
Old Oct 23, 2010 | 07:15 PM
Tap the centre hole instead of welding nut, or are they not very thick.
Old Oct 23, 2010 | 07:16 PM
Liar, you use some of the vaseline you always have hanging around!
ps you going to be there monday ?
Old Oct 23, 2010 | 07:57 PM
Toe Knee's Avatar
Toe Knee
unfortunatly its already got a hole drilled in the middle which is bigger than what i need doh!! but its the right size and round so ideal to use and was free cant complain lol
Aug 29, 2015 08:16 PM
cos4ever
Ford Escort RS Cosworth
Aug 26, 2015 10:05 PM
john_3.0s
Aug 15, 2015 07:44 AM
Aug 14, 2015 07:29 AM
track.focus'd
Aug 12, 2015 05:53 PM
